Conical compression springs
Mode
Tool
Workspace: Tool set
Modes for Creating single lines
Conical Compression Spring
Architect and Spotlight: Machine Components
Landmark: Add tool to workspace
(see Customizing workspaces)
Multiple compression spring tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
The 2D conical compression spring is a linear object, while the 3D conical compression spring is a point object.
To insert a conical compression spring:
Click the tool and mode.
Conical compression springs have ends of unequal diameter. When you draw a spring, the first click defines the large end of the spring, and the second click defines the small end.
Parameter
Description
Display
(2D only)
Select a display mode for 2D springs
Wire Diameter
Enter the wire diameter (thickness)
OD - Small End
Specify the outer diameter of the small end of the spring
OD - Large End
Specify the outer diameter of the large end of the spring
No. of Active Coils
Specify the number of active coils in the spring
Working Length
Either specify the spring working length value, or click and drag a spring control point to define the length graphically
Spiral
Select either a Left Hand or Right Hand spiral direction
Draw Center Line
(2D only)
Draws the spring with center line(s)
Compression springs 1 and 2
